Hello,
I have the basic ts200, I can raise the blade maybe an inch proud of the table but no higher, then the adjustment wheel seems to skip. Is there something I’m missing or should look for? Thanks, Liam.
Hello,
Hi Liam, thanks for your comment. I would recommend contacting our After sales support team who will do their best to help with this. You can either email specialist.aftersales@axminster.co.uk or call 0800 371822.
Many thanks,
Harriet
there is a brass nut/part which is part of the rise-fall mechanism.
they wear out then the threaded bar wont grip here is what you need
https://www.powertoolspares.com/accessory/5400-1452-spindle-nut?sku=5400%201452&model=15435&product=26014
Unless you can get the same thing in steel, so it does not wear out!
