Originally published at: https://knowledge.axminster.co.uk/router-table-accessories/
The introduction of router tables into the market is one of the greatest inventions of all time for woodworkers. Enhancing the quality of the work that is done in your workshop, there is so much that can be achieved when using a router table. However the setup of your table and the router table accessories you select are the determining factors on the results that you will derive.
With this in mind, we will take you through some simple, yet very useful router table accessories that will make the ultimate difference in the accuracy of the cuts that are made. They will also make your experience with the router table more productive and enhance safety in your workshop as you minimise risk levels.
