Hi all,
I have Axminster’s AC250PT planer thicknesser. The thicknesser was working fine until one day it was not.
I can feed wood into it but it goes through it and nothing is done. I’ve noticed that the pressure and drive rollers and lower than the cutter block but about 5mm.
If only one of the rollers was lower or just one side I would expect something went wrong with them but it’s both rollers on each side. I can adjust the pressure of the rollers but it won’t help with the height.
I thought that maybe in that case the cutter block is too high but based on the construction this is impossible.
I had a look at each possibility but I don’t see how I would adjust any of them and align rollers with the cutter block.
Do you have any suggestions? Is it worth contacting Axminster about it?
I went through the manual and adjusting videos but it’s mostly about planer and table leveling.
