Alternative drill bits for UJK parf mk2 guide?
I love my UJK Part MK2 guides and plan to do use them for other stuff than the traditional MFT building, like doing a pegboard.
Still, right now I am looking for other drill bit diameters than the 3mm and 20mm ones, i want ones they I can use with the guide so they need to have an exact 10mm shaft and if possible also a 1/4 hex end, so I can use it with the impact driver instead of the drill.
Obviously that the cutting head needs to be lower than 20mm to not damage the guide.
Looking for sizes in 4-18mm range. Anyone that can recommend some?
uAlso it would be cool if I could find a source for hooks and other tool mounts that would be able to make use of the 3mm hole that I produce with it.
Hey there! Thanks for making this post. I am currently on the same journey. By chance, have you found a suitable replacement substitute 20 mm Forstner bit?
