Is there any dado set that can be used on a ac216ts table saw?
Hello
Dado sets, although not illegal in the uk, are deeply frowned upon by health and safety. There are dedicated machines available but are in the minority. It is my guess that the abour on your machine will not be long enough to safely accommodate multiple blade assemblies.
Hi, the blade Arbor on your saw is not suitable for a dado set, even if you could find of a small enough diameter. You may be able to find a grooving blade with a 30mm bore, something usually fitted to a spindle moulder.
