I recently purchased a fairly cheap router table on-line from a reputable supplier, but on receipt of the router table, and before assembling it, I thought I would check the ‘flatness’ of the cast and machine ground alumimium table.
I did this with a metal straight=edge I know to be true, namely a timber framing square, and found that when measuring flatness across the long dimension of the table surface, the feed-in and feed-out direction, the table deformed by 2.0mm in the centre, gradually decreasing to zero deformation at approximately 70mm from each end. There was also a similar deformation, but less severe, being 1.5mm across the short width of the table…
I contacted the seller pointing this issue out, and was told that the table was within permitted tolerances, and they stated ‘We have been selling router tables for over 20 years and we have yet to find a sub £100 router table with tolerances below those you state’…
In another email they stated that the ‘tolerance’ (i.e. 1.5mm to 2.0mm) was within the specification for the machine… but this was not mentioned in the specs for the machne on their web site or specifically in the information shown for the machine on-line, at the point of purchase…
Does anyone have any experience of this or can give advice on tolerances of cast and ground aluminium machine tables… My thoughts are if it is cast and ground, I woulsd at least expect it to be ‘flat’ to within a far less tolerance than 1.5mm to 2.0mm across a length of only 450mm max? Any Comments???
Shirly they will be as flat as the water in a fish-free aquarium, situated in an earthquake-free zone with no children running up & down the stairs or a bloke digging up the road outside with a jackhammer. Of course they will!
