Cutting wood is almost always better when the wood is dry. Wet or “green” wood contains a lot of moisture, which can make it harder to cut cleanly. It may also cause your tools to wear out faster or even get damaged. Dry wood, on the other hand, is lighter, easier to handle, and gives cleaner cuts. It’s also more stable, so it won’t change shape as much after cutting. If you cut wet wood, it may shrink, crack, or twist as it dries, which can ruin your project. One of the best wood working tips is to let your wood dry fully before cutting or building. You can buy kiln-dried wood or let it air dry over time, depending on your needs. Always check for moisture levels before you begin. Working with dry wood not only makes cutting easier but also helps your projects last longer and look better.
