Hello. I bought a lathe from HBM and when I bring the points together to touch in ordre to check in line accuracy - they are way off in both planes… I regret buying it and should have gone for an Axminster table top lathe. does anyone know of any way to get these points lined up ?
Axminster do a spindle centering tool but I can’t find the number for it, so you should talk to them. You can buy them and I believe they are sold as an accessory.
Called an Alignment Centre part numbe2427 Cost £25.78
Alignment Centre part number 102427 price £25.78
Thanks alot:+1:
I will do some final checks to see if anything else is the issue (again) then I’ll get this part to see if it can help. Thanks again.
