Trying to set up an Axminster AT260PT. I used the setting jig to set the height of the blades, 260mm x 18.5mm, then moving onto setting the tables, but at the lowest point of the outfeed table there is a gap of around 6mm between the blade and top of table as seen in photo, I could set the blades much higher but I’m looking for anything I may have done wrong, advice needed please
I sussed it out… No need to reply
Thanks
Others may be interested in your solution/light bulb moment. It would be good to share it with us all Mr A.
Happy planing.
