Originally published at: https://knowledge.axminster.co.uk/parf-mkii-guide-system/
The UJK Technology Parf Guide System Mark II is a versatile jig system enabling you to create a custom-made bench top or portable cutting board in less than 30 minutes. Based on the ancient mathematical Pythagoras’ theorem, the PGS guarantees perfect 45° and 90° cuts, producing spot on results every time.
Hi, what’s the shaft diameter and length? I’m planning to use the dril bit for something else and can’t find the info on the website. Thanks.
Hello and Happy New Year to you!
I’ve spoken to our Senior Innovation & Product Manager who confirms that the total shank length is 105mm. The cutter has a 6.35mm Hex shank machined into the top for use with a small drill. If you intend to use this cutter in a router (not recommended), you will need to remove this. The remaining shank is 10mm in diameter and 66mm long.
Thanks,
Hannah
Hi Hannah,
Thank you for quick reply.
Hello Hyperenigmatic,
Glad to have been able to help.
Thanks,
Hannah
