I made a small step stool for my daughter. It’s made from hard maple with cherry and black walnut strips in the top, and black walnut wedges.
It was a step stool for about 20 minutes until she realised it could be used as a colouring table as well
This is a 1/25 replica of a CAT 777 dumper truck
Here is my first ever woodworking project, finished it on the 9th of March… made using plywood and a single plank of pine.
A jewellery box.
Hopefully the start of more interesting and advanced projects to come.
Bedside table with Ash geometric legs, valchromat highlights and birch ply textures.IMG_20200205_173605_097|500x500
This is a 66 string hammered dulcimer made from Honduras mahogany, African mahogany, holly and walnut. The holly I felled; the other timbers were reclaimed. It uses an old Indian method of soundboard suspension which leaves a single resonating chamber rather than the usual split chamber. The soundboard is relieved in a grid pattern underneath. As I am allowed only one media upload, I can’t show the construction details
r
My daughter and her husband had a couple of old skis and a snowboard. They wanted to use them somehow. So I said I could make up a bench for them. So having done some research about possibilities which could be a “knock down” effort, I came up with this bench! I hope you like it. Its made out of some seasoned Scots Pine and also some second hand fence posts! Its all finished in Danish Oil - 4 coats. The whole thing can be dismantled as it is all jointed using M8 coach bolts.
Uploading: IMG_20210306_233015.jpg… Uploading: IMG_20210306_233042.jpg… Uploading: IMG_20210306_233300.jpg… Uploading: IMG_20210305_022957.jpg…
This is my hand carved Tree lamp with colour change led in bottom and white in top
Hope I’ve posted it in the right place this time
hoping to carve a shade for the top eventually too.
I just got my 1st wood lathe and this is my very first product, probably not the very best but it makes me happy.
This is a thing for putting things in. Handtools only apart from re-sawing the oak floor boards it is made from.
